Is the Ugoos UT3S is a good choice?
Recommended Device on RK3288
Some of the problems are related to the SDK (Software Development Kit) by rockchip so you will find it at nearly every device (e.g. problems at some AVR's at the moment, ... )...
If you have a look at the "forum-action" you will find out that the most action (also mods) is at the devices which using the Netxeon pcb (Beelink / UBOX / Tronsmart) but the latest stock roms are at the devices which uses the T-Chip pcb(s) (Ugoos UT3(s) / Nagrace HPH)...
So Ugoos UT3S isn't a bad choice...
RK3288 Devices
- Overview BOX (LINK !)
There are currently 2258 users online. 0 members and 2258 guests.
