Help! Partition table of X7S
I found that there are 16 partitions at EMMC memory, Does anyone tell me what is functions of these 16 partitions? Any one can advise how to remove all and install a new win81?
You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
Originally posted by lifeisfunCreate bootable usb stick win8.1 bing oem edition, and just boot from it and do clean install
After you are done just install all drives from the pack Bob posted.
Do all windows updates and you are done.
It will activate it self, since the key is saved in the bios.
Originally posted by lifeisfun View PostYes, just erase all when installing incl. the recovery if you don't care for the android, I sure don't on this device.
Just a clarification...did you wipe all partitions ? In another post you mentioned to keep 100 Mb WIndows temp.
Also, I managed to find two 32-bit OEM Win8.1 with Bing. One of them says International version. NOt sure which one I need to activate with key in BIOS.
Thanks for your help
UPDATE: USED the non-international edition and it worked well. I wiped out all the partitions and ONLY then I was able to get the 29.1G of available storage space tom install windowsLast edited by sfernan; 13 June 2015, 16:07.
But please only if it fits to this rule http://freaktab.com/forum/tv-player-...218#post494218
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_meBut please only if it fits to this rule http://freaktab.com/forum/tv-player-...218#post494218
Originally posted by rfwagner View PostI already found a ISO from bing, but I think the wrong is provide keys, since this w8.1 with bing will install in our PIPO because we already have the keys, but not the files, that are ours already, just need to reinstall. Am I wrong?
I did this and installed successful, but I still with the dual boot screen. Do you know if I need to delete all of that to get rid of it?
There are currently 3354 users online. 0 members and 3354 guests.
