Cube U30GT 2 (1.05) 900 supersport ROM
    I've just released a RK3188 ROM for the Cube U30GT 2 based on cubes 1.05.
    Cube u30gt 2 (1.05) 900supersport 1.1 ROM
    Notes
    • Flashing will delete everything on your Cube consider backing up first and remove any sdcard
    Instructions
    • Download and extract to a folder
    • connect the tab to the PC (you did remove the sdcard)
    • start the ROM flash tool
    • put the tab into flash mode, the PC should detect it, see below for instructions
    • install drivers if required
    • erase idb
    • flash, the ROM kit is correctly configured
    • the tab should boot to recovery and format cache, data and sdcard (this will take a few minutes)
    • the tab should now boot
    Let me know how this goes.
    So what do you get?
    • defaults to english uk
    • root
    • some bloat removed
    • busybox and init.d support
    • play/market fixes for more apps in Google Play
    • 2 gig app space (this is standard on the stock ROM)
    Booting to Bootloader
    • Power off the Cube
    • hold Vol +
    • After 3 to 4 seconds release Vol +
    • The Cube should be detected by the PC.
    • If you have not already installed the drivers now would be a good time. I've included the drivers in the ROM kit in the RockusbDriver folder.
    Finally thanks: to Geekbuying who supplied me with the tab so quickly and at a discount, to Tattman65 who created the boot screens and to all the devs and mods here at Freaktab
    900Supersport
    freaktab developer
    Re: Cube U30GT 2 (1.05) 900 supersport ROM
    Brian, how's that upload going?
    Randy
    Randy
      Still going.
      900Supersport
      freaktab developer
        Upload completed
        900Supersport
        freaktab developer
          will give this ago, 4.2.2 seems to have a few issues, any change log on this ? Thanks again
            so which way to go?
            beta or this official???
              You'll find the change log on cubes site.
              I really like 4.2.2 myself, but have seen some criticism of the camera, battery and sound.
              900Supersport
              freaktab developer
                thats what i picked up too. so far a nice rom but still some things to figure out for cube to make a 4.2.2 based ron a final one.
                i think there are driver problems with the built in components.
                that possibly is the reason for the bad benchmark scores.
                So i guess i'll go with the official one and a 4gb app partition. the fastest stable thibg out there it seems.
                  NOW I got my Cube in my hands. It is coming with V1.03 preinstalled.
                  Things that came to my mind:
                  - There are blisters under the display cover - I had to remove it to see if display itself has problems, but no
                  - Now Display CLEARLY has a better feeling and the image instandly becomes more crisp and deeper.
                  - I 100% advice to remove display cover (not the one with the advertising)
                  - tablet goes completely nuts when charging. it was impossible for me to navigate within google market.
                  - Power cutted and everyhing is fine.
                  - After flashing V1.05 tablet does behave normal when charging....one time phenomenon???
                  Remember....DO NEVER EVER Connect this thing to a USB3 Port!
                  I connected the tablet to USB3 ports I´ve got on top for easy access (LianLi PC-7FN Chassis)
                  It is a Windows7 Pro 64bit machine by the way!
                  Corruped recognizing repeatedly and drivers could not be installed. Since there are now Windows8 drivers included I got a feeling it was USB3. Connecting the tablet to a backside USB2 port everything instandly runs the way it is meant. Drivers for Win8 x64 were installed without any problem.
                  Now I was able to flash supersports ROM. I wanted a 4GB Partition so I renamed the parameter files to my need.
                  So what about the CWM now?
                    I am using fun's CWM, did I not link it in post 1 or the download notification.
                    900Supersport
                    freaktab developer
                      CWM Installation:
                      I found this over at another board: http://uploaded.net/file/9ugkaxhj
                      1. Download
                      2. Unrar
                      3. Use flashtool as already learned
                      4. Don´t change anything and you´ll be fine
                      PS: I get 16785 antutu points
                      Hardware-Number V3 (do we all have this?)
                      CPU runs at only 1,6Ghz. 1,8Ghz can not be chosen...A tool to set the cpu to full power is missing.
                      !!! THANKS GO OUT TO FATAZ WHO BUILD THIS NICE PACKAGE !!!
                        Originally posted by Magnifico View Post
                        CWM Installation:
                        1. Download
                        2. Unrar
                        Hi, yes i got about 16785 antutu points as well with 1.05 , you use supersport to flash CWM ? or rockchip flash tool ? what are benfits of CWM ? also would like to adjust to 1.8ghz , why was it advertised at 1.8ghz ?
                        THanks
                          If you don´t know CWM yet you don´t need it.
                          CWM? > http://forum.xda-developers.com/wiki/ClockworkMod_Recovery
                          Interesting tool for you guys as long as there no themes available for flashing.
                          POWER TOGGLES: https://play.google.com/store/apps/d...51bGwsMSwyLDNd
                          normal view (possible):
                          opened menu view (possible):
                          Live wallpaper used: https://play.google.com/store/apps/d...2Nvc21mcmVlIl0.
                          Weather widget(s): http://uploaded.net/file/ab6wlnk3
                          !Unpack and install as normal APK.There are two widgets....choose the one you like!
                          Test File for CWM: http://uploaded.net/file/xcznei5u
                          !Gives you Galaxy S3 Sounds!
                            NEW BETA!
                            Cube release a new open Beta 2013.05.07
                            Known imprements (Wifi...Video playback) but also there are several system optimizations mentioned.
                            Waiting for this one.
                              Yes I'll be downloading later.
                              900Supersport
                              freaktab developer
