MK902II - AV Out - HELP!
This is my first android device which I bought to output to a number of different screens, including screens without HDMI. Seems to work quite well, with one exception. I have tried to connect to a screen via the AV out but no signal is sent. HDMI works just fine. I have tried changing the Output Interface menu item to AV but nothing changes, it continues to output via HDMI (even if HDMI disconnected). Settings are as per the attached! Any help appreciated, as it's driving me mad!
Tags: None
If I'm not wrong only HDMI OR AV (not and) and needs reboot (sometimes more then once)...
Also be sure you use the right version of AV-cable (worst case change the cinche cable/plugs)...RK3288 Devices
- Overview BOX (LINK !)
Yes, that was the way I had to do it at the UBOX (never tried it at the Ugoos)... but it also doesn't work after the frist reboot (maybe after the 2. or 3. and I have no idea why, sorry...)
EDIT: or maybe after unpluged PSU ???RK3288 Devices
There are currently 998 users online. 2 members and 996 guests.
