PIPO M6 PRO - Battery life boost question
    Hello All,
    I have a long flight coming up and seem to get very disappointing battery life from my PIPO M6 PRO. I am on the latest Riley Kitkat.
    Do any of you have any advice for getting better battery life? At the moment I get about 2.5 Hrs.
    Is the Jellybean rom better?
    Also, has anyone sussed out a portable charging solution for the pipo? i.e. via usb?
    Many thanks
    Zoot
    for such a low battery life you could probably have a battery failure or have always GPS set to on...
      That's the life I get while watching movies - What sort of time should I be getting?
        You should get more or less 6 hours watching movies with medium brightness.
          I get nothing like that.
          If I do a factory reset will I have to install gapps etc?
            no you don't,
            paystore etc... remain installed
