Pipo M9 Max 1Nand
    Pipo M9 Max 1Nand
    So i was able to send and receive my pipom9 motherboard (i had a bad NAND and esc btn broken) to PIPO.
    It took some time but they did as promissed and fixed both issues, and it is working again.
    But now i face 2 more problems:
    The tablet powers on and boots as soon as I connect it to power, but the POWER/STANDBY button is no longuer working (it used to work fine until i send it).
    Allso, the touchscreen is allso not working and i had to use a mouse to navigate the tablet.
    I tried to install a different ROM to see if that would solve those issues, but when I connected it to the computer (in debug mode) i realised something starnge, the drivers were missing and the batch tool is in PINK.
    Allso Drive E: and F: (the ones from the tablet) are not avaliable, i cannot connect it to the PC.
    If i press the SWITCH, tablet will go to black screen and the bellow features:
    (see PIC1) (still no access and the PC no longer detects it)
    If i disable debug mode it is ok, and i can access the tablet, but i get the same result when i press switch.
    If i use RKAndroid tool it says no driver detected if i press Rebbot to flash mode, although it detects rkandroid rock usb
    I allso have a PIPO M9 pro that works perfect, and i'm very used to change its ROM so I know what should happen here.
    I have already tested it on Windows 8 windows 7 and XP. Allways the same result no driver.
    After they sent it back i have no word of them, but i was very satisfied with the service so far.
    I have no clue what i can still do can you guys help me?
    I remind you that this is a M9 MAX with only one NAND.
    Thank you so much in advance
    So i was pressistent, read a lot everywhere, ended up getting some proffit.
    I can now accees the whole tab features, recognize it and flash it anyway i want.
    Apparently it was windows 8.1 problem (read it somewhere) I installed a pair of different drivers and i can easily flash it on xp.
    But the touchscreen problem pressists, i have reseated and cleaned and reseated the connector like 10 times... the digitizer and cable are in mint condition, it even has an untouched protective film with the top plastic to remove, no apparent reason for it to stop working.
    Could this be ROM related? would flashing the LOADER do any good?
    Another curiosity, My M9 Max only has one NAND, so i assumed it should be the old PCB, but when i flash for instance Pipo M9 Max 4.2.2 RileyROM 1.6 [OLD PCB version] or any ROMS with that reference i get no screen image after flashing.i think it is working because i can hear the windows sound. And the process terminates successfully.
    I'm on Pipo M9 Max RileyROM 2.4 now and all works ok except for the touchscreen.
    I could really use a help here, cmon guys.
    Thank you
      Here's my shell log:
      <4>[ 6.958444] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.958483] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.959317] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.959356] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.960168] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.960207] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.961014] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.961052] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.961875] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.961915] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.962729] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.962769] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.963583] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.963623] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.964438] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.964478] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.965289] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.965328] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.966143] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.966182] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.966996] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.967035] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.967843] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.967883] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.968739] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.968781] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.969592] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.969633] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.970444] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.970484] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.971301] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.971341] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.972155] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.972195] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.973010] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.973049] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.973863] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.973903] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.974717] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.974756] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.975568] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.975607] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.976415] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.976455] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.977265] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.977306] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.978116] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.978155] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.978976] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.979016] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.979818] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.979857] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.980683] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.980724] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.981537] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.981577] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.982392] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.982434] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.983244] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.983286] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.984094] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.984133] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.984949] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.984988] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.985801] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.985840] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.986649] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.986689] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.987502] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.987541] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.988356] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.988396] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.989214] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.989254] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.990068] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.990109] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.990921] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.990962] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.991773] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.991813] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.992626] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.992666] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.993478] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.993517] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.994330] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.994368] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.995178] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.995218] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.996030] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.996069] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.996882] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.996922] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <4>[ 6.997735] [<c080ae6c>] (ct363_init+0x60/0x230) from [<c0809cf4>] (ct36x_ts_probe+0x138/0x378)
      <4>[ 6.997776] [<c0809cf4>] (ct36x_ts_probe+0x138/0x378) from [<c081b164>] (i2c_device_probe+0xc0/0xfc)
      <3>[ 6.998972] ct36x_ts 2-0001: CT36X chip: Failed to get fwchksum
      <3>[ 6.999000] ct36x_ts 2-0001: Failed to init ct36x chip
      <4>[ 6.999031] ct36x_ts: probe of 2-0001 failed with error -11
      <6>[ 6.999381] input: lightsensor-level as /devices/virtual/input/input1
      <4>[ 6.999526] lightsensor us5151 driver created !
      <6>[ 7.059368] logger: created 256K log 'log_events'
      <6>[ 8.444667] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
      <4>[ 9.812238] randomizer = 2 , EccBits = 18 pSpec->pReadRetrial = 0
      <6>[ 9.936557] EXT4-fs (mtdblock8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
      <6>[ 9.977847] EXT4-fs (mtdblock6): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
      <6>[ 10.052934] EXT4-fs (mtdblock5): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
      <3>[ 11.678407] i2c i2c-3: 1 i2c clients have been registered at 0x3cProbe ov5640_back_3 success
      <3>[ 12.928404] i2c i2c-3: 1 i2c clients have been registered at 0x30
      <6>[ 42.707130] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
      <6>[ 42.737016] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
      <6>[ 43.090163] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
      <6>[ 43.143357] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
      The driver fails apparently.
      I don“t even know if its HW issue or SW issue.
      Any help guys?
        Are you sure it is a VTL CT363 Touchscreen? Perhaps they gave you a new Goodix? Read the log to see if it tries to load a Goodix TS later on.
        Try my kernel from the dev section
        Donate to Finless
          Well, i tested your kernel, all ok, tab rebboted after.
          Pinguins screen then dead....
          It won't even power now reset+back button not responding, pin short not reponding...
          My luck is this big....
            Wow! Sounds like you are doing all the right things. Usually it is pretty impossible to brick a Rockchip
            Donate to Finless
              The power button is damaged, so maybe it stopped working... I mean, the tablet it's completely unresponsive.
              It only charges
              This is not normal,
