All the box is used for is kodi....
Mxiii out of space
Mxiii out of space
So I'm new with the TV boxes but I have tinkered with the phones a bit. Today my mxiii 2g/8g box says it's out of space. I cleared cache's, tried about everything I could think. Got enough cleared out that kodi would run smooth. What I'm now trying to figure out is what I can do to get the stock Android thing better with more room(apps are 4.3 gb and the "misc" folder is 4.7gb I can't figure out how to access that folder though it what it is). Should I flash twrp and try another rom or I'm not sure...just kinda stumped.
All the box is used for is kodi....Tags: None
Originally posted by mxx20 View PostSo I'm new with the TV boxes but I have tinkered with the phones a bit. Today my mxiii 2g/8g box says it's out of space. I cleared cache's, tried about everything I could think. Got enough cleared out that kodi would run smooth. What I'm now trying to figure out is what I can do to get the stock Android thing better with more room(apps are 4.3 gb and the "misc" folder is 4.7gb I can't figure out how to access that folder though it what it is). Should I flash twrp and try another rom or I'm not sure...just kinda stumped.
The only way to fix that is to uninstall the bulk of these things to free up some room. Otherwise with 2G of RAM you should have been otherwise ok.
I think I might have found an Easter Egg. If you hold down the Menu Button for ~2s The MBOX's (like boot screen), pops up, you'll probably note the Rocket since its on screen longer! And, clears the Cache, from wherever. I do this from time to time inside Kodi, as I only have a 1G Device. But, the only time I've ever seen an insufficient storage available error, would be on my old ass Samsung Phablet. joke here being that it has an additional 12 something GBs of SD Storage thats no longer usable under KitKat. Due to how Google has gone outta their way to ostracize all MicroSD Cards since then. Basically ensuring that they can ONLY ever be used as READ ONLY Media.
I didn't install everything lol... I finally got to dig into it last night and the thumbnails it saves in kodi that for some reason has never cleared. 1.something gb worth I still need to dig into it. Kodi is showing its 3gb in size compared to another box we have(not a Mxiii tho) it's three times the size easy the other box is smaller
But yes I probably did screw something up...
There are currently 1683 users online. 0 members and 1683 guests.
