Today Blackview Annoucement their latest widescreen Smartphone, it is BlackView Alife P1.
It has a MediaTek MT6735 quad-core SoC is equipped with 64-bit technology and a 5.5-inch HD screen.
It comes with 2GB of RAM, 16GB of storage plus an 13-megapixel rear camera paired with a 5-megapixel front facing snapper.
The capacity of battery is slightly improved , it is 2600mAh,bettery than Alife S1 .
Most strikingly, it comes with fingerprint sensor which is same as Meizu and Samsung.
Also it comes with the New Android OS 5,1 Lollipop.
Here are the Technical Data of it:
Specifications | |
Brand/Model | Blackview Alife P1 Pro |
Operating System | Android 5.1 |
CPU Type | MTK6735 Quad-core |
Product Type | Android Phone, |
4G | 4G LTE Smartphone |
Screen | |
Screen Size | 5.5 Inch |
Screen Type | Capacitive |
Multi-point Touch | Multi-Touch |
Screen Resolution | 1280*720 HD IPS |
Memory | |
RAM | 2GB |
ROM | 16GB |
Max Storage Expansion | 32GB |
Camera | |
Front Camera | 5MP |
Rear Camera | 13 MP |
Flash Light | Support |
Communication | |
WIFI | Support |
GPS | Support, GPS A-GPS |
Bluetooth | Support |
Network Frequency | GSM 1900 / 1800 / 850 / 900 WCDMA 2100 / 850 FDD-LTE 1800 / 2600 / 800 |
Functions | |
Gravity Induction | Support |
Distance Sensor | Support |
Light Sensor | Support |
Others | |
SIM Card | Dual SIM Dual Standby |
SIM Card Type | One Standard Card, One Micro Card |
Battery Capacity | 3000mAh |
Data Cable | Micro USB |
Accessories | Cell Phone: 1 SIM Needle: 1 Power Adapter: 1 USB Cable: 1 OTG Cable: 1 Earphones: 1 |
Languages | English, German, Spanish, Italian, French, Portuguese, Russian, Indonesian Language, Thai,Arabic, Turkish, Vietnamese, Malay, Greek, Chinese (simplified), Chinese (traditional) |
For me it seems to be a Really Good Device with the most Feature you needincluded LTE for the most Network Speed.
