MK808 CWM Stuck Screen
    Sup guys, I got my MK808 about 2 months ago, three days later I was running finless 1.7c, thanks Bob. Today after reading a post here I decided to install CWM. The update.zip file on the sd card was recognized on boot-up and I installed it. Now I'm stuck on the following screen.
    Reboot system now
    install zip from sd card
    install zip from sideload
    wipe data/factory reset
    wipe cache partition
    backup and restore
    mounts and storage
    advanced
    I'm using a Logitech m510 wireless mouse that has no effect on above screen. I have a funny feeling that there is something really simple I'm missing here and hope someone can point me in the right direction. Thanks in advance.
    Re: MK808 CWM Stuck Screen
    Reboot system now
    backup and restore
    mounts and storage
    advanced
    Sometimes some hubs and keyboards are hard to use.
    With mouse you must move the mouse up to get a step up in menu, or move mouse down to get an step down, don't expect to see the cursor
    My devices:
    Gearbest.com)
      leolas thank you for your reply. The problem was a usb issue, I was finally able to get past the screen by pluging a wired mouse into OTG port. I still could not get past the screen till I rebooted. The device then had a normal start-up.
      Thanks Again
        Thanks Again
        Good
        My devices:
        Gearbest.com)
