VSMART Q8 revision Q8L-WW236 ST modified Ricomagic firmware
    Hi, guys!
    This is Ricomagic RKM 902 II "MK902II_150401" firmware which adopted to new revision of VSMART Q8 - "ww236 st".
    Till now only RKM worked for prevoius hardware version of Q8.
    AND YOU INSTALL ON YOUR OWN RISK. JUST READ ALL BELOW CAREFULLY:
    Whats declared by RKM and shoud work:
    1 - Update the blue ray library,audio track can be switched.
    2 - Support BD ISO 3D playback.
    3 - Fixed Keyboard/Mouse lag issue.
    4 - Fix some Incompatible problems of some apps in Google play store.
    5- Update ffmpeg video libary,fixed some blurred screen issue.
    6- Optimize USB camera
    7- Update root code.
    8- Default HDMI CEC turn on.
    9 - Passthrough spmc and kodi fixed.
    10 - Iperf wifi program installed stock.
    11 - Improved wifi perferance.
    12 - Improved performance for Video
    13.- Support ext4 format u disk and exfat sd card
    14.- Fix some 4k -h.265 problems.
    15.- Better browser support.
    What added:
    16. - There are 3 launchers added
    17. - Hardware encoding support for all video formats
    18. - Original remote control fully supported
    19. - Optionally you can flash for 3.8 Gb system size, just use during flashing firmware parameter file from par4free folder
    What currently not working:
    1. - Wifi display not properly work
    2. - Power off from Android menu cause restart instead power off. But can be used sleep mode, just press "Power off" hardware button for sleep.
    Download here https://yadi.sk/d/0mL2oS29h8Twm
    Before install please check your hardware, must be sticker with "q8l 2g/8g 2015-03-10 ww236 st" Click image for larger version
    __________________________________________________ ______________
    IMPORTANT - NOT WORKING for:
    XT-Q8L-V10 2014-09-02 with label Q8L 8G/2G XT20140919395 ST
    ENY-Q8P-V10 2014-09-02 with label Q8P 8G/2G XT20140919395 ST
    XT-Q8L-V10 2014-09-02 С with label Q8L 8G/2G XT201410154 ST
    If you try to flash these models you'll brick your device, and need to use maskROM flash mode with original firmware for models above
    HOW TO FLASH:
    1. Power off your device, unplug the AC adapter
    2. Install Rockchip drivers from here http://blog.geekbuying.com/index.php...download-here/
    3. Plug in MicroUSB cable into microUSB slot on your device.
    4. Run AndroidTool.exe from firmware archive above
    5. Press R hidden button with thin stick and hold
    6. Plugin USB cable in your computer
    7. You must see Android tool window with "Found One LOADER Device" Click image for larger version
    8. Release R hidden button and press Run button on the AndroidTool software and wait for firmware ends
    9. After flashing device can restart several times with message "Optimizing apps". This is normal situation.
    Links for latest original "q8l 2g/8g 2015-03-10 ww236 st" firmware, if you want revert back:
    http://www.mediafire.com/download/t9...g_20150424.zip
    or
    Hi!
    I have the XT-Q8L-V10 2014-09-02 with label Q8L 8G/2G XT20140919396 ST, what is needed to do in order to make this firmware compatible?
    PCB photo:
      Originally posted by andrevergilio View Post
      Hi!
      Hi, this compatible only for ww236 ST revision.
      You can't install on your device.
      You can install pure Ricomagic RKM 902 II firmware, but mpeg4 hardware encoding, some other hardware encoding and remote conroller will not work.
        sorry, i've posted here something in wrong place
        how can i delete this post?
          Hi
          I bouth one Q8 and installed this rom.
          How i play 3d.iso movies?
          This box only play in 2D not in 3D? Am I doing something wrong?
            Originally posted by tarasbub View Post
            Hi
            Do you used poper software installed?
            I never tested 3D.
            Please try to reflash with kernel and resource, link here https://yadi.sk/d/XtMheEpLhFbkq
            You DO not need reflash ful firmware, just check only resource and kernel as shown below: Click image for larger version
            PLEASE SAY IF 3D working with these resource and kernel. You can revert back to previous kernel same way.
            But REMOTE not work with that kernel, but power off works.
              Hi.
              Not work too.
              For try to watch 3d.iso i used: internal player, kodi 15, mx player.
              all play only in 2d
                Hi paparazzo,
                A few questions...
                Will there be updates/fixes?
                If i want to return to the stock fw, the same procedure applies?
                Thanks!
                .A.
                  Hi paparazzo,
                  Would it be possible to port MK902II_20150529 to "WW236 ST" boards?
                  Is there a procedure written somewhere how to do it? I'd give it a go...
                  Thanks!
                    Hi. Is anybody here? Can I use this soft for devise with sticker Q8L 2g 16G XT20141204567 ST? This WW236ST Version? Thanks.
                      You will probably brick your device.
                      Better to save and buy a RK3229 or RK3399 in a few weeks when it gets released from a different manufacturer.
                        Mo123, and there is no alternative? it`s same sad...
                          There is no hope, there is just going to be frustration.
                          Never buy cheap, always look for quality and support, in the end it's worth it.
