upgrade Amlogic S806
* Amlogic S812Quad-Core Cortex A9 2.0GHz*OCTA Core MALI 450 GPU* 2GB DDR3 + 8GB Flash* Android 4.4.2* 4K x 2K resolution* H.265 UHD hardware decoder* HDMI 1.4b, supports 3D* 802.11 b/g/n Dual Band 2.4GHz/5.8GHz WiFi, Broadcom AP6330 module* Bluetooth 4.0* 13.2 XBMC Pre-installedHardware Spec: Operation System Android4.4 Language Chinese,English...Multi-Language support CPU Quad Core ARM Cortex A9 Amlogic S812 GPU Eight core ARM Mali-450 GPU up to 600MHz+(DVFS),OpenGL ES 1.1/2.0 and OpenVG 1.1 support SDRAM DDR3 1GB/2GB Nand Flash 4GB/8GB/16GB/32GB Storage Extension IEEE 802.11 b/g/n 2.4G/5.0G Module RTL8188/AP6210/AP6330 The extended storage Does not support Power Supply DC 5V/2A 3.5mm DC-in Camera 200W 500W Interface: HDMI Out HDMI HDMI2.0 to support maximum 4Kx2K display USB Port USB Host Data Output SPDIF Card Readere Does not support AV Out 3.5mmHeadphone Jack Network RJ45 10M/100M/1000M Power Supply DC Jack Antenna External WiFi antenna Media Parameter: Audio Container MP2/MP3/WMA/WAV/OGG/OGA/FLAC/ALAC/APE/AAC Audio Out HDMI Data Output Video Decoder DAT/MPEG/MPE/MPG/TS/TP/VO8/ISO/AVI/MP4/MOV/3GP/FLV/MKV/M2TS/MTS/M4V/WMV/ASF/RM/RMVB Video Encoder Resolution H.264 Data Rate Up to 60Mbps Image browser Text-Reading Support TXT,LRC,PDF,Html,Htm,EPUB…etc formats(Depends on APK install) Software Extension DLNA,Miracast Protocol Remote Control IM Software Support Skype/QQ/MSN/GTALK (Depends on APK ) Offic Software WORD/EXCEL/PDF(Depends on APK install) Others Parameters: Operationg Temperature -10~40℃ Storage Temperature -20~50℃ Humidity environment 5%-90%(No condensation) Certification CCC,CE,FCC,Wi-Fi
if ur referring to the CX-S806 box then I don't know of any custom firmware's with Android. I do know there is an openelec version if your looking for a Kodi Only Experience. www.amlinux.ru/image has the Openelec version.
if you need android software, you can have it from acemax website
www.acemax.net.cn downloading center
There are currently 2261 users online. 2 members and 2259 guests.
