Thanks a lotssssssssssssssss
MK808B with WIFI problem
I just bought a MK808B from Geekbuying.com and I having problem with connect with WIFI to my WLAN router, my router is a D-link Model # Dl-524 802.11G/2.4ghz with WEP 64bits encryption enable, if I disable the WEP encryption then I can get a connection, I don’t know why? It drive me nut, anybody having the same problem or know how to fix it, any help will be greatly appreciate. I attach some screen shot hope that will help.
Thanks a lotssssssssssssssssTags: None
Yep... WEP is dead long ago. It is easily cracked.
WPA2 is the standard.
There are currently 3421 users online. 0 members and 3421 guests.
