MK808B plus - some apps are diplaying in portrait - phone mode, instead of landscape - tablet mode - how to solve it ?
    One of the "must install" apps for me is Samba Filesharing server for android (now it is removed from google play, but still available on xda-dev here:
    http://forum.xda-developers.com/andr...droid-t2803452 )
    I have used this app on the old MK808 (rk3066) and MK908II (rk3188) both with Finless ROMS without troubles.
    On MK808B Plus with Finless 1.1 there is an issue: the app is starting in "portrait phone mode" (the problem is there also in the stock ROMS) - as in the attached capture. There are other apps with the same behaviour, Clean Master is an example. (screenshots are somehow scrambled on these apps and unusable, so I was forced to make photos).
    The big issue, is that there is no "MENU" button, or at least I do not know where it is, in order to launch specific commands such as "Settings".
    Please help,
    Thank you,
ID:	505401Click image for larger version
    You cau use Rotation Lock Adaptive app or Xposed framework and App settings module to force landscape mode.
      Sorry for late reply, thank you very much, Rotation Lock was the perfect solution !
