[X7s] There is a way to wipe Android partition and later recover it?
Deleted android data , immediately stop add new files into your android phone. Because when you add some data/files ,the phone internal memory will be occupied. the more you write data . You will not be able to retrieve lost files from android phone .
How to delete android appsLast edited by Bacckloo; 17 August 2015, 03:18.
You can re-size and re-install using the following
http://freaktab.com/forum/tv-player-...ipo-x7s-w8-etc
Samsung Data Recovery is powerful recovery program that aims to recover deleted data from Android phone. You need to download and install it on your computer .Once connect your phone to the computer, you can optionally preview and recover deleted data .
Before you wipe Android partition, you can backup your Android phone with Android file manager tool. So after that, you can easily recover it.Last edited by weixiao; 23 December 2016, 03:20.
You can use an android assistant tool to backup the data from your phone. After you wipe Android partition, you can recover them back.Last edited by Loie; 29 June 2017, 03:04.
There are currently 2517 users online. 2 members and 2515 guests.
