MXiii 1GB Stock Recovery?
    Hi Guys,
    Can anyone point me in the direction to download the stock recovery IMG for the MXiii 1GB model?
    I tried flashing the K200 twrp but now I can't boot recovery!
    Any help is much appreciated.
    Sent from my SM-G920F using Tapatalk
    Since I can neither upload the raw recovery.img File (Format not allowed), or zip it down to the ~5MB limit.
    You'll just have to pull it out of a MicroSD update yourself. These are the same MicroSD Updates that you usually find (e. 108k4 ~ 115k4)
    I'd normally post a Beelink address here... But, since they ditched their "Support" Pages... There isn't much need... I guess you could go to the Stock Firmware - Beelink S82 / M8 - MXIII 1/2G - Official FW Release from Beelink Page - 119, and download the Tronsmart 115k4 Firmware from there. unpack that as you should to get the standard Three Files One of which is your recovery.img File.
      Great, thanks for you help mate. I'll try this tomorrow
