Bricked OTT M8? No Blue Light
    I was trying to install Finless rom 1.8 but now the box will not boot and doesn't show the blue light!
    Anyway to unbrick?
    Board is Original V0.92 with Samsung memory
    When i plug it into my computer it shows as M8-CHIP
      Fixed it
        Hi Just wondering how you managed to fix this after. Thanks
          Please you can help i have same problem
            Can you give me schema usb to.otg and driver
              Bugs are Sons of Glitches!
              JustMe
                i cant connect my m8 with usb this is my board i solder jumper
                  now my box is connected but i need img rom
                    IS HE connected good ?
                    this is my sd card
                    2 files uboot.bon and .wps
                    its so right?
                      now u have this problem
ID:	508583 Click image for larger version
                        you are getting error
                        1.when you see red.
                        2. you need to press the reset button in the av jack hole then connect power then plug in the usb cable and you should here your pc pick up the device and say connected. then you can hit start.
                        3. also update you usb burning tool later version function better and also have full english text when select chinglish as your now :-)
                        JustMe
                          I can flash it witout using sd card bootable?
                            PLEASE give me rom jusme .img
                              sir justme i have this problem you see my box is connected i dont know how i can fix this problem
ID:	508868 Click image for larger version
