Kodi XBMC Picture errors, Tronsmart / MK808B Plus with AP6212 WiFi chip
Hi, its a well know problem..
Its the amlcodec that outputs only 1080p
-just disable it..
Results, are also dependant on what version of kodi..you are using
Hmm..wait i remember again,
You (johnoo) and me...allready reported this bug to oman (24:11:2014)
mitchell4you, Disabling amlcodec introduces a whole load of other problems,
like picture stutter after 30 mins, etc ..
also without amlcodec, if you stop playback and start another video/stream
the box defaults to software decoding, which is unusable for HD.
Disabling amlcodec is like removing the main engine from a truck
and trying to run the truck on a small motorbike engine, not really a solution.
109k4 firmware works great, but Wifi does not work with new boxes cause of different Wifi chip.
Originally posted by Johnoo View PostDisabling amlcodec introduces a whole load of other problems,
109k4 firmware works great, but Wifi does not work with new boxes cause of different Wifi chip.Looking for developers
what version of Kodi are you using to compare? is the one installed in the ROM or are you using the apk from www.kodi.tv. I ask cuz I always uninstall the one in the ROM and install the one from the site and haven't seen any issue your experiencing with my 111k4 stick.
There are currently 2070 users online. 0 members and 2070 guests.
