Beelink i826 - very disappointed!!! >>>S812
    i tried the new firmware 116k4 from here http://pan.baidu.com/s/1kT5UI6z
    my question is, are:
    1 ) anyone able to run flash with the standard browser
    2 ) nab game time always crash at the start, anyone else having this problem (https://play.google.com/store/apps/d....nba2011&hl=en)
    3 ) airpin pro can not play airplay videos send by iphone very smooth and mx player also wont open streamed videos to (if you choose it as an external player (http://tinyurl.com/ncw7929)
    i must say that i own the minix neo mini x5 to and have no problem with all these on that device, bought the beelink just because i tought that the spec is similar to the minix 8 devices!!!
    How did you find this?
      i got it from this post...
      Hi folks, Just in time I've got this new box (from Gearbest), after my previous S82 box died when (2nd time) tried to fix HDMI with soldering... yeah, I messed up
        just looking at this threat i found out that there are more issues with Beelink Boxes
        http://freaktab.com/forum/tv-player-...230#post284230
        Code:
          [COLOR=#333333][FONT=arial black]Known Issues->[/FONT][/COLOR]
        1.Force landscape mode;
        2.Jerky playback for Xvid AVi;
        3.Youtube,iPlayer playback issue;
        4.1080P 24Hz;
        5.1080P to 720P switch problem;
        6.F10pro /rii mini i7 Layout,and suspend function;
        7.xbox and ps3;
        8.Ethernet speed downgrade after suspend;
        9.upgrade using usb stick;
        10.CEC suspend function;
        11.Sync playback to display;
          Last edited by [URL="http://freaktab.com/member/48717-oman"]oman[/URL]; 07-10-2014, 01:30 AM.
        ...so maybe people sould rather go for minix boxes if they want solid roms!
          I have had tronsmart s89 and mxiii, tronsmart mxiii, no problems with any of them tbh. Some of those issues are fixed, some exist on minix as well, because it is chip not box maker (s802). All are same as beelink.
          I think u have installed a weird ROM?
          You need to install 202k4, not 116k4?
            Hopefully you didn't buy this beelink junk from gearbest like I did. Good luck to you if you did. Stay away from Beelink junk people!! You have been warned!!!
            Hopefully ill be able to get back at least $5 from gearbest so I can buy a minix from somewhere far more reliable and who actually cares about their customers.
              When you look at some of the basic issues that come out of the factories from day 1, it does kind of tell you that they do very little in the way of testing before releasing them for sale, or they do test but decide to withhold the info from prospective purchasers.
                1) Flash is defacto ipsum dead on Droid, and has been since ICS! So your answer would obviously be no!, and do you really want to be running a Flash version that like, a whole Seven versions back from the current bug / Security hole ridden Flash?! Trust me its not worth it in >2015!
                I have no idea about 2) & 3), as I do not have this Box.
                EDIT:
                About 2, Seeing that this is an Intel x86 Box, it might not work... But, you might want to check your Build.prop, and if need be enable the Widevine DRM there by changing the Flag from FALSE to TRUE. I know this to be the standard behavior in the 1xxxk4 line of Firmwares post 107k4 anyway. It may well prove well to look into it.
