first.. thanks for the HELP!
I bought this android tv box quadcore 1.5ghz... it's amazing...
I have two problems... need stock image and need to root it...
1) what is the manufacturer (I don't know)? Where I can find the stock firmware for it ?
2) I want to root it, but it fails...
when I go in the recovery mode and flash the supersu.zip from pendrive,
after boot , I call supersu icon and It says "binary is outdated..." I select "normal update" and it fails)
this is my device... (I bought MXV AMLOGIC S805... with bluetooth and wifi)
but when I call a program to stream play stream tv it says (MBX pufangda S805)
MXV Amlogic S805 Quad Core A5 1.5GHZ TV BOX Android 4.4 Kitkat 1G DDR 8 GB ROM Support 2.4G WIFI H.265
(this is the seller where I bought ) => http://goo.gl/D5eaSI
I don't know what is the manufacturer and I need to get stock image (actual or the last or another better)...
