Help Me to find Best Dual boot Mini Pc
    Hi, its' time for me to move on from my cs968 tv box and to buy new tv box Based on the dual boot os.
    I'm heavy Kodi User so I need strong unit with windows that can run kodi smooth.
    Allso i have tv Servics like Netflix that works with silverlight so i need tv box that can run silverlight with no lag and choppy video.
    I have 4 external Hard Drive so i need a tv box that I can plug the hard drive to the USB without any problem or power connections.
    last but not least...i need a tv box that doesn't have heat issue, i don't have the time and passion to open the tv box and to install some cooling units inside
    can some one recommended tv box that Meet my needs?
    Wintel w8 works great for me
      Netflix use the Windows app no effort at all, Silverlight can get a choppy, RKM MK 36
      Have a good read around Freaktab.
      Cheers
        At this point in time, unless you really need one quickly, I'd wait a few weeks for the Cherry Trail Atom X series devices to hit the market.
        They have started to trickle out and I saw one of the first phones to feature the atom X3 today, so I would say that they are imminent, which may possibly also explain the plethora of deals recently as they try to clear the shelves of current stock.
          Also the PIPO X8 is a good Device with Dual OS of Android and Windows.
            Yep must agree after a more fiddling with the X8s both in Android and windows it does work well and has a built in screen that has to be a good
            Cheers
              PIPO X8S? I only see x8 without the s, I'm' missing something? what about heating issue?
              what about
              Tronsmart Ara IZ37 Dual OS Smart TV Box
              http://www.****.com/itm/Tronsmart-Ar...1ad5647​
                My Bad was thinking of the X7s
                Yes it is just the X8 the heat is not as Bad as X7 but a simple mode can keep it cool bit of alloy and Thermal Pad.
                Yet to see the Tronsmart ARA
                Cheers
                  can you link this phone please?
                    This one.
                    It's a low end model but I reckon there will be a plethora of them very soon.
                    Asus has announced the Zenpad series of tablets too.
                    Driven by innovation & committed to quality, ASUS has a wide selection of best in class products. Find & buy a laptop, phone, router, monitor, motherboard & more
                      dual system, RKM MK36
                        Yep even I will agree with that.
                        New Ainol mini PC II is looking good also
                        Cheers
