i bought one of this popular MK809IV clone dongle (with red slider antenna) from the auction site (Kitkat, RK3188T 2GB/8GB with RTL8723BS wifi chipset). Unfortunately, it has two problems: it is locked at 720p and does not support USB multi-touch devices (in particular the HANNS G 231HPU that i am trying to pair it with).
I have tried many kernels available here for the same chipset at least to get HD resolution, but no luck so far, as the stick just wont boot. Also to fix the 2. problem, I started to recompile my own kernel with the source provided by D33 in the thread Kitkat Kernels for All - thanks a lot for that! First kernel alone just to flash the kernel and boot partitions, and then the whole image using complete android build with kitkat source provided by Radxa. However, both to no avail - the stick just wont boot.
Maybe somebody could check and hint me to something that i have done/configured wrong? I attached here build.prop and dmesg from my stock kernel, and my .config used for kernel build. Any hint/help is much appreciated as i have stuck here for quite long time. I am using the linaro 4.6.2 tool chain.
Thanks again and best,
