hi friends
I have a mk808b device with JB 4.2.2 Official - Finless ROM 2.1 rom
I'm going to download large files (bigger than 4GB) but FAT32 only support under 4GB
I changed sd card format to EXT3 with MiniTool Partition Wizard Free but device doesn't recognize sd card
is there a way to add file bigger than 4GB to sd?
