8.1 Bing to Pro using a key
Originally posted by bluesmanuk View PostHas anybody tried or managed to upgrade their Bing copy of Windows to Pro buy using a purchased key?Please consider making a Donation to freakTab
Originally posted by blinkone View Post
Post 24 here http://freaktab.com/forum/tv-player-...dows-8-1/page2 Bob says he has installed pro & used his pro key to activate it so it can be done..I guess most user's will upgrade to windows 10 but if your a pro user & you like it why not.
Cheers.
So it looks as if you have to a clean install and no ability to update solely with a key.
Perhaps it is due to the key being embedded in the hardware.
Yes from what I understand the key in the bios will only work with windows 8.1 bingPlease consider making a Donation to freakTab
There are currently 2177 users online. 0 members and 2177 guests.
