MK808 Stuck in Mask Rom Mode
I think you are right, this unit should be compatible with the original mk808 firmware.
Try to flash this rom: http://blog.geekbuying.com/index.php...core-tv-stick/
If it does not work, try the following things:
- a different version of flash tool. Here is the one i use: https://www.dropbox.com/s/w350iskkrx..._v1.6.zip?dl=0 (flash the firmware using the "Restore" button)
- try different USB cables and USB ports on your PC
- try a different PC
If nothing of the above helps, try this: http://freaktab.com/forum/tv-player-...d-on-the-mk808
I had a similar issue recently with my MK808: It turned out that the power supply from the PC USB port is too weak for the flash process. So what I do now is starting the MK808 with the PC USB connection until the flash tool finds it, and then I turn on the additional normal power supply before starting any flash process. This works reliably with my stick and I erased and reflashed several times recently...
BTW, still looking for a good 4.4 ROM for my MK808 (should be 1080p and with fixes for the most common problems like not saving the screen scaling etc...), see here:
http://freaktab.com/forum/tv-player-...-rom-for-mk808
Originally posted by tycapel7 View PostThank you for that markust, Im definitely going to give that a go later. Before i do, could you please recommend the best rom to flash to the MK808 at the moment. Thank you. Robert.
I think I would stay with Finless 2.1 for the time being.
I have not yet found a good 4.4 ROM.
There are currently 1683 users online. 1 members and 1682 guests.
