Anything that looks for a connected device and has an option to boot to bootloader.
Stuck
Re: Stuck
Anything that looks for a connected device and has an option to boot to bootloader.900Supersport
freaktab developer
Originally posted by 900supersport View PostAnything that looks for a connected device and has an option to boot to bootloader.
i have tried
Fix 1
start the flash tool
connect the cube
press power for 15 seconds to force power off
press vol + then press power and keep them pressed for 4 seconds releasing power then vol +
and then the picture is
what should i do after that friend?Last edited by fansdroid; 05-08-2013, 22:37.
That's the stock recovery I've only used it a few times. From this screen I think either vol+ and then power or power and then vol + will bring up a menu. It won't do any harm to experiment here and if you get to the menu try clearing cache, factory reset or any other options. Does the tab get detected by the pc/flash tool when in recovery?
I came close to getting stuck in a recovery loop while experimenting with some cwm recoveries. I had to start the flash tool and restart the tab, and watch for it being detected so I could press the button to restart in bootloader. In most cases I've been able to force the tab off with long power then connect to USB while holding vol+ to get boot loader.900Supersport
freaktab developer
My ROM kits have all the drivers. What version of the cube do you have?900Supersport
freaktab developer
Originally posted by 900supersport View PostThat's the stock recovery I've only used it a few times. From this screen I think either vol+ and then power or power and then vol + will bring up a menu. It won't do any harm to experiment here and if you get to the menu try clearing cache, factory reset or any other options. Does the tab get detected by the pc/flash tool when in recovery?
i have tried per itemin screen shot,but after i reboot the tablet did stuck in logo again friend
Originally posted by Neilcee View PostThank you, i am downloading the Cube U30GT 2 4.2.2 v3 evaluation 900 supersport ROM. i am running w8 on my computer is that ok or a daft question? The RKBatchTool_1.5 doesn't have w8 drivers so i am guessing thats why they are not installing.
Those drivers should be fine but you need a ROM for the u30gt not the u30gt 2.
Try http://www.freaktab.com/showthread.p...supersport-ROM900Supersport
freaktab developer
Originally posted by fansdroid View Postmy cube is cube u30gt2 friend,sorry,i think you said with me
Have you downloaded ones of my mor kits for the gt2?900Supersport
freaktab developer
It will make it easier to help you if if you are using tools I know. Have you flashed a ROM or late you on the original that came with the tab?900Supersport
freaktab developer
Originally posted by 900supersport View PostIt will make it easier to help you if if you are using tools I know. Have you flashed a ROM or late you on the original that came with the tab?
and i try to use that rom, but in rom flash tool written no found rkandroid usb.my tablet is not unknow device.not detected
can you tell me about"put the tab into flash mode"?
Hold power for 10 seconds then release. This should ensure the tablet is turned off.
Start the flash tool.
Hold vol + and connect USB. Release vol + after a few seconds.
Is an unknown device detected, if so you need to install the drivers from the ROM kit.900Supersport
freaktab developer
Originally posted by 900supersport View PostHold power for 10 seconds then release. This should ensure the tablet is turned off.
There are currently 2619 users online. 6 members and 2613 guests.
