!MINIX Hybryd FW Status Bar Themes!
    I found some time to play with "Status Bar".
    This themes are for people who are bored with the stock status bar look.
    Install:
    First using "es explorer" make a backup of /system/app/SystemUI.apk
    Unpack the downloaded package. Rename SystemUI_xxx.apk to SystemUI.apk.
    Using "es explorer" (check root in es settings) copy downloaded SystemUI.apk to
    /system/app/ folder. You wil get error mesage "Unfortunetly, System UI has stopped."
    Do not panic;p
    Reset your device. After the reebot there will be no status bar.
    Go to es explorer and once again copy SystemUI.apk to /system/app/ folder.
    Reset your device one mor time.
    Now after boot you wil have "System Bar" you wanted
    As always if someone have a question just ask.
    New themes will folow.
    Download:
    SystemUI Cyan v1
    SystemUI Cyan v2
    SystemUI Magnata v1
    SystemUI Magnata v2
    SystemUI HFW
    SystemUI White
    Everything is possible if we work together!
    ApkFreak
    GREAT WORK, Lewy!!!
    Can you create a transparent StatusBar, too?
    For example with 25%, 50%, 75% and 100%.
    Cheers
    Frank
      Re: !MINIX Hybryd FW Status Bar Themes!
      Originally posted by FBK2904 View Post
      GREAT WORK, Lewy!!!
      Cheers
      Frank
      The space for the status bar is not in the desktop, so for this, when you run antutu or xbmc its said that you haven't 720 or 1080.
      Great idea lewy, I mod the statusbar in my phone and tablet, but never thought about made it in my stick.
      My devices:
      Gearbest.com)
        yap. leolas is right, no transparency for now:"
        ApkFreak
          How do we download these?
          Your links open a cloud share site that needs a username and password.
          I like the looks of the different bars and would like to try them.
          Also, I like the background, where can I get that and others?
            links are fixed.
            ApkFreak
