This themes are for people who are bored with the stock status bar look.
Install:
First using "es explorer" make a backup of /system/app/SystemUI.apk
Unpack the downloaded package. Rename SystemUI_xxx.apk to SystemUI.apk.
Using "es explorer" (check root in es settings) copy downloaded SystemUI.apk to
/system/app/ folder. You wil get error mesage "Unfortunetly, System UI has stopped."
Do not panic;p
Reset your device. After the reebot there will be no status bar.
Go to es explorer and once again copy SystemUI.apk to /system/app/ folder.
Reset your device one mor time.
Now after boot you wil have "System Bar" you wanted
As always if someone have a question just ask.
New themes will folow.
Download:
SystemUI White
SystemUI White
SystemUI White
SystemUI White
SystemUI White
SystemUI White
