Android Smart TV Box won't startup
    Originally posted by neomode View Post
    Did you use a Micro USB Cable and Connect to PC?
    Also, you installed the Driver for Rockchip?
    Read here for a How-To --> http://radxa.com/Rock/flash_the_image
    Ray
    Hello "neomode", in the interesting website of Radxa the Rock board appears that it has a CPU with Rockchip RK3188 however our Andoer CS918 or CS-918T has a SoC Rockchip RK3128t, then in Radxa Rock board all prebuild images are not builded against RK3128t, then can you tell us where we can download the lastest stable firmware and compatible for this Andoer CS918 RK3128t 2GB RAM/16GB Nand flash Android v4.4 smart tv box?. Answer please and thank you very much
      O.k it should be a Andoer CS918 Android 4.4 TV Box.
      You must reflash the Firmware. Let me check for a Firmware for you.
      Ray
      Hi Ray
      i have on my Andoer CS918 HX_3188 Android TV Box
      My box is using KitKat 4.4.4 and it is rooted, but there is no menu option for "Developer options",
      I can not see it in using ADB or Fastboot, and when i use connect the USB cable my computer does not see it
      i have installed the USB Drivers via the Rockchip Driver Assitant v4.4
      what else i can do to get the USB Debugging on to connect to my computer and be able to use ADB and Fastboot to try to update and/or flash a new boot image
      AVBestDeals
        You have to unhook the dev options.
        Go to about box and there on kernel or version you have to kick fast 3 or 4 times then it will be enabled
          Yes i did as always click on the About::Build 7 times but no developer option in the setup menu as the norm in most android boxes
ID:	595412 Click image for larger version
ID:	595413 Click image for larger version
ID:	595411 Click image for larger version
            see pics above
              If any one has the stock factory firmware for the above tv box, please if you could share with me.
              As i was editing the built.prop and reboot and it is now stuck in the boot animation logo screen.
              So i need to re-flash the firmware back to factory settings,
              and this box does not reboot with the connect to pc option so i could pusn the file via ADB
                I have the same box and I was not lucky to find the stock firmware or custom rom. If anyone already have it please let me know. Thank you.
