New Firmware Zidoo X9 V1.0.3.5
    Zidoo X9 firmware update v 1.0.3.5
    Update system
    1. Added the PIP function, You can press the TV button on the IR remote to open it.
    2. Optimized the compatibility of audio.
    Player
    1. Solved the problem that audio menu displayed error. (For example, when you play the first video and switch to the second audio track, then play another video, the result shows it plays with the first audio track, and it’s the second actually.)
    2. Removed the hints of optional between feature and tidbit, when playing BDMV and ISO files.
    3. Changed the OSD Timeout from 3s to 6s in the connection play of hints menu.
    4. Changed “Turkey” into “Turkish” in the subtitles.
    File Manager
    1. Added the prompt optional of whether pop-up the USB device.
    2. Solved the problem that clicked on the filter with failure.
    3. Solved the problem that occurred white screen when entering LAN-> play video-> HOME-> return application.
    4. Removed the prompts of delete or paste when completed successfully.
    Alternate link if having trouble
    Cheers
    Alternate link for Zidoo X9 v1.0.3.5 firmware on mega
    https://goo.gl/7MnJUr
    Zidoo X9 @$99 Coupon: WZQGOWTA
    Valid: 4th Aug 2015
      I tried the new firmware. PIP did not work. It only stops all audio from passing through from cable box. I also could not get audio recorded with this update.
        That is weird, working well this side, suggest try a reflash it may not have gone in 100%.
        Have a bit of look over at the Zidoo forum if you still have issues.
        Cheers
