THanks and best regards,
Any recent dongle stick (HD) that would work out-of-the-box with USB touch screen HANNS G HT231HPB?
Thanks a lot for the info, Neomode. There seems to be boxes that work: http://freaktab.com/forum/tv-player-...979#post349979 and also the box provided/bundled by HANNSPREE with the monitor. But i really want to have it as a stick so that i can hide and hang it with the monitor to the wall.
Furthermore it seems to be a simple fix in the kernel in order to enable the support: http://forum.odroid.com/viewtopic.ph...tart=80#p35246. I am not sure if it has made into the main linux kernel for android yet.
I am just not able to compile any bootable kernel or to find a bootable custom kernel for my stick (GXT_DP19_LP_V1.8 with RK3188T) thus probably have to look for an alternative (at least where i can compile and flash a bootable kernel)
Originally posted by liha0400 View PostHi Saahib, thanks a lot for the information. Could you please check and post the linux kernel version of your stick and possibly the link to the product. There are so many clones so that i want to be sure to get one that really works ;-). Thanks,
RK3188T, your stick uses a 3.0.36 kernel, thus it's too old and don't have support for lots of drivers. No way to put a newer kernel version on your device.
If your have your kernel source and the touch screen driver that is compatible with your kernel, you could build a new kernel.
There are currently 2721 users online. 0 members and 2721 guests.
