I know that the S812 is not exactly new, but this device is hitting the market at a great price so i decided to share it where with you all. I will probably get myself one, my first S812
I'm indicating Gearbest, probably you can find it somewhere else but i have dealt with them previously and have nothing bad to say. And they are our Advertisers also, so you know they are legit.
Some photos for the eyes, it looks exactly like the previous model but with the power of the S812 inside.
Main Features:
● Comes with a RJ45 jack for 1000M Ethernet which provides a strong network extension.
● In a follow-up OS, it can be upgraded to Android 5.1.
● True 4K x 2K resolution which delivers best audio and video quality for you.
● Powerful Amlogic S812 Quad Core CPU and Octa Core ARM Mali-450 GPU: Stable and reliable.
● XBMC supported. XBMC can be used to play almost all popular audio and video formats.
● Android 4.4 KiKat: Rapid and stable, gives you access to over 800,000 apps including Facebook, Youtube, Picasa and more.
● Professional H.265 video decoding technology and 2.4G WiFi, offering a more stable WiFi signal to enjoy a higher quality video experience.
● 2GB RAM + 8GB ROM, 32GB maximum extended capacity gives you more space to download your favorite apps and caches to browse websites, play games, run apps, watch movies more smoothly.
● Bluetooth 4.0 connectivity: Easy pairing with most Bluetooth-enabled devices (computer, mobile phone, keyboard, and others).
● HDMI 1.4 connector: You can go directly to let your TV and MXIII-G are connected through a HDMI cable and set up your home cinema for the best 4K x 2K Full HD multimedia experience.
● 2 x USB host ports and 1 x OTG port: Connect with your mouse and keyboard to help you operate more convenient.
● Infrared remote control let you enjoy your wonderful life which the wireless brings to you.
● Support Miracast, DLNA.
You can pre order one on GEARBEST site. You will also find some more info on their page
http://www.gearbest.com/tv-box-mini-pc/pp_202596.html
Don't miss out
