Sent from my GT-P3100 using Tapatalk 2
T428 vs 908
I would also like to know what differences there are between two devices.
both devices have the same WiFi and Bluetooth chip?
edit:
"Some RK3188 mini PC will use AP6210, others AP6330 like T428. AP6330 can support 5Ghz WiFi frequency, but AP6210 just supports 2.4Ghz. There's about $10 US difference between the two modules. GeekBuying tested the connection with a 5GHz router and it works, however they don't have 802.11ac router yet, so they decided to remove 802.11ac from the listed specs for now"
Guest
The t428 have a better wifi module that support also 5ghz
But not only this. With this configuration is more compatible with many firmware.
For example is compatible also with the cube tablet firmware
And for now the t428 have a good 4.1.1 firmware in wich all is very stable
Originally posted by turboblade View PostWhat are peoples opinions on which is best
There are currently 2921 users online. 0 members and 2921 guests.
