HPH RK3368 TV BOX will be release soon!
pllease kindly see below board pic
SPEC:
CPU:RK3368 28nm Cortex-A53 Octa core up to 1.5GHz
GPU:PowVR PV6110 Support Microsoft DirectX9.3 OpenGL3.1, OpenGL ES 3 compliant
DDR/Storage: 2G/16G
WIFI moudle: AP6335,2.4GHz/5GHz WiFi 802.11 b/g/n and 802.11 AC.
Support LAN 10M/100M/1000M Base-T, AP6330 OPTIONaL
Power Supply:5V/3A
OS: android 5.1
HDMI Output: 1xHDMI (A type Female), HDMI2.0, Support 4K×2K decode output
USB Port:3xUSB Host,1xOTG
Fibre-optical Output:1xSPDIF
AV OUT:1x3.5mm earphone Jack
Network port:1xRJ45
Antenna:WiFi external 5 db antenna
Media Parameter: | |||||||
Audio Container: | Support MP1、MP2、MP3、WMA、WAV、OGG、OGA、APE、FLAC、AAC、M4A、3GPP… etc Audio formats.Muliti -EQ mode,Support Synchronized lyrics and full-page lyric display | ||||||
Audio Out | HDMI output data directly, simulation R/L audio output, optical fiber digital audio output | ||||||
Video Encoder | H.264,MOV,3GP RV, VP6/VP8, Sorenson Spark, MVC |
Video Decoder | Full video format decoding support.Support format MPEG-1, MPEG-2, MPEG-4,H.263, H.264, AVS, VC-1,RV, VP6/VP8, Sorenson Spark, MVC | H.265 4096*2304 60fps H.264 4096*2304 30fps MPG4 1920*1080 60fps MPG2 3840*2160 30fps VP8 3840*2160 30FPS |
Video output | HDMI output: Support 4Kx2K ( 3840*2160) @60HZ AV output:PAL & NTSC |
H.265 Data Rata: | Up to 60fps | ||||||
Image browser | Support JPG、JPEG、BMP、GIF、PNG、JFIF…etc photo format.Maximum resolution up to 8176*8176 | ||||||
Text-Reading | upport TXT、LRC、PDF、Html、Htm、EPUB…etc formats(Depends on APK install) | ||||||
Software Extension | Support Google Play & APK install | ||||||
Protocol | Support DLNA,Miracast Protocol,Support DRM requirement.airplay Audio push | ||||||
Remote Control | Support Smart phone remote control、BT, 2.4GHZ wireless air mouse/Remote controller | ||||||
IM Software | Support Skype/QQ/MSN/GTALK (Depends on APK install) | ||||||
Office Software | WORD/EXCEL/PDF(Depends on APK install) |
