MKV809IV
    MKV809IV
    TV Stick: GXT_D16_LP_V1.8 150310
    hello
    NEEED HELP
    Does anyone have a rom for this stick?
    have quite a few roms but tried Unfortunately, this does not wifi.
    this rom works but no wifi : http://freaktab.com/forum/tv-player-...699#post349699
    I've tried this kenel but the wifi does not work : http://freaktab.com/forum/tv-player-...237#post387237
    description from ****:
    Smart TV Box Stick Android 4.4 Quad Core 2G/8G XBMC DLNA WiFi US MK809IV Mini PC
    CPU
    Rk3188T Quad Core 1.6 (Cortex-A9)
    GPU
    Quad Core Mali 400
    Ram
    DDR3 2GB
    Rom
    On board NAND Flash 8G
    Expand Micro SD
    T-Flash(Maximum support 32GB)
    Video Format
    MPEG-1/MPEG-2/MPEG-4/H.263/H.264/AVS/VC-1/RV8/RV9/RV10/VP6/VP8/Sorenson Spark/MVC 1080P@60fps(1920x1080)
    Audio Format
    Support: MP3/WMA/APE/FLAC/AAC/OGG/AC3/WAV
    Picture Format
    Support: Max.8000x8000 JPEG BMP GIF PNG
    support 802.11a/ b/g/n
    Bluetooth
    Support Bluetooth 4.0
    Output
    HDMIPort
    Ports
    1*Micro USB,Support OTG/HOST ( USB port RJ45)
    1*standard USB
    1*TF card slot
    1*Micro USB for power
    1*Physical botton(For upgrading software)
    OS
    Google Android 4.4
    Dimension
    105mm*40mm*10mm
    DC
    5V 2A
    Weight
    <40g
    Working environment
    5‹C--35‹CC30%--90% Humidity
    Storage environment
    -20‹C--60‹CC10%--90% Humidity
    thanks very much
    Excuse me for my bad english
    You may only view thumbnails in this gallery. This gallery has 5 photos.
    Hello
    I have found the original version of this stick and uploaded to mydrive.ch
    you can download the original version from the TV Stick: GXT_D16_LP_V1.8 150310 on
    www.mydrive.ch
    Username: freak@onlinetobi
    Passw.: freakdhb
    the rom on www.mydrive is: D16_20150601_1845_2G_8G
    You can find the rom on this page to
    regards
      Next
        Originally posted by Sillium View Post
        News
        I tested the version (D16_20150601_1845_2G_8G) and the stick crashed all the time. this is the original version that was preinstalled.
        now i have installed version D16_F_2G_8G_20150625 and that works perfectly and without errors. :-) Perfect. This version you ca find on http://pan.baidu.com/share/home?uk=3...ategory/type=0
        best regards
        Sillium can you upload this img to a public server such as dropbox or googlegrive the link you posted requires china phone number to regester before download
          I have the exact same device, however it is extremely slow working (kitkat 4.4) and has stuter problems running hd video's. frames keep skipping. also very slow wifi.
          i have so far tryed at least 10 different rom's and kernels and none will boot the device except the original rom from ( https://drive.google.com/file/d/0B_w...ZEOXJNaDg/view ) that has the problems.
          i undertand that the problem is in the vsync of the kernel but i have been unable to get the perl script to run and dont understand enough about the process and how to execute it.
          i have uploaded the original kernel file to dropbox ( https://www.dropbox.com/s/byjaxsoceq...ernel.img?dl=0 )
          so if someone can help me with it i would be etornaly gratfull.
            I have also bought this MK809IV (and I can confirm what PrometheusQue is stating: slow working with KK 4.4.2. The wi-fi is terrible, and I am at 2,5 meters from my Wi-Fi router. Nevertheless a cheap toy, and I am digging further whether its performance can be improved. I actually tested one pcs. first, but the Wi Fi was so bad that I had to change it. The new one has better wi-fi, but strangely it shows only 3 GB of NandFlash and 2 GB of RAM. I am not sure whether it is a hardware problem or something is messed up in the Android. In the meantime I see there is not much movement around the capabilities of this toy so maybe we can communicate better on available resources. The baidu links above are totally inaccessible for me also, so maybe Sillium can provide the downloaded versions.
            Thank you all ...
              News
              best regards
              Hi Sillium, Any chance of loading the D16_F_2G_8G_20150625 rom somewhere? Like the others here I can't download it from the link you gave.
              much appreciated
                Hi
                  is the D16_F_2G_8G_20150625 rooted?
                    here you can download the files.
                    www.mydrive.ch
                    Passw.: freakdhb
                    the rom by Diman3452 is rooted and works perfectly.
                      www.mydrive.ch
                      Passw.: freakdhb
                      no this rom is not rooted
                      thanks, This I was looking for.
                        so a rooted rom doesen't exist? I want to run Linux installed in a SD card. Is it possible?
                          tried this rom too. it will not run 720p / 1080p video. (stutter like crazy and unwatchable) boot time is way too slow and everything is sluggish to extreams.
                            My modified D16_F_2G_8G_20150625
                            root
                            init.d
                            unified memory
                              Hello, this is the only Rom that works with this device ??
                              i got a problem playing videos in netflix.
