I own this device since last February and i mainly use it for watching movies/tv series through Kodi (ex XBMC) software. Untill now my impressions of using the R89 were great.
Today, after searching for movies on Kodi, i tried to stream and watch on line but i noticed that the sound coming out from the device had some issues. It was a little distorted, human voices were not heard as they should and also there were some interrupts (small but hearable) on sound.
I tried watching 3 or 4 different movies since then, but always the same problem appears on sound. I tested TV (LG 60PB5600 Plasma) speakers and they sound OK through TV programs.
I m afraid that maybe somethings wrong with R89 hardware, perhaps because of heat (room temperature 29 degrees Celsius). Device case was a bit heated but nothing extreme i would say.
Did anyone of you had similar problems with R89 sound?
I should mention that no rom updates or any other hardware modifications have been made to the device.
Thank you for your support.
Lazaros
