System:
1.Add the entrance of system settings,can find the Setting ICON among all the applications;
2.Add root function;
3.Add Supersu.apk;
4.Add the closing process prompt of multitasking bar;
5.Add the function of USB installation, to achieve installation all app in USB DISK with one button;
6.Modified shortcut function, to make it faster;
7.Modified zdrepo, let it shows the webpage path;
8.Optimized the fluency of system.
UI:
1.Modified the problem that it would not lose some Vietnamese words.
Player:
1.Optimized the switch function of 24Hz.
ZDKodi:
1.Fixed it would get black screen in some case;
2.Fixed it would not smooth in some case;
3.Add the function of frame rate can switch automatically;
4.Changed the default font is arial.
OTA ZIP file : http://apidl.zidoo.tv/ota/zidoox1/do...a-20150710.zip
How to upgrade: http://blog.zidoo.tv/2015/02/how-to-...o-x9-firmware/
IMG(Please download this file then unzip it):http://apidl.zidoo.tv/ota/zidoox1/zi...1.0.15_img.zip
There is some risk for flashing your BOX, Please be quite careful to make it.(It will clean out user data entirely, please be cautious to do it.)
How to Flash : http://forum.zidoo.tv/index.php?thre...-firmware.398/
