Pipo M6 Pro Dead?
Pipo M6 Pro Dead?
Hi, unfortunately after having a lock of my tablet, the same did not want to turn over. I tried the whole sequence of keys to put loading firmware but nothing. That is, to be precise: I connect it to the PC I press the buttons to make the driver recognize rockusb to put it in bootloader, is recognized for 2 seconds and then again I say tablet not recognized. I wanted to know if it is bricked? ThankTags: None
Your problem could be caused by a number of things.
1. What version of Windows are you using? Have you successfully flashed your tablet from the same PC? It could be the driver. The Rockchip driver doesn't work with Windows 8.1. Try a different PC with Windows 7 or earlier.
2. Are you using the USB cable that came with the tablet? The stock USB cable has a longer micro USB connector that reaches further into the tablet's port.
3. Are you using a USB 2.0 port on your PC. RK drivers aren't compatible with USB 3.0.
4. What does the flash tool say when it recognizes the tablet. Does it say "Loader" mode or "Mask" mode. If the tablet shows up in "Mask" mode, and you haven't opened the tablet and shorted pins on the NAND chip....then you might have a bad NAND chip. If that's the case, then YES your tablet is dead, because it can't operate without a working NAND chip (unless you can figure out how to get the tablet to boot from the external SD...which I have no experience doing, myself). I believe there are some posts here on Freaktab that explain how to boot a device from external SD.Randy
There are currently 1898 users online. 3 members and 1895 guests.
