I have tried a few versions of the windows based mini pc's, even the v1900 which is more powerful and with a 8GB RAM config and still I get the same issue on Kodi:
- I define zero cache as I have done on many Android TV boxes so that it will buffer all streams including local LAN ones (all my movies sit on my main PC which sits about 20 meters away)
- the buffering works very well with all internet streams no issues there.
- the problem starts with the local shared files. Then all hell breaks loose. The movie will eventually stutter and freeze even though there is plenty of buffer already!
I have looked hard everywhere and even plugged a separate more powerful wifi dongle with gain antenna and still nothing. It happens mostly on 1080p movies but with Android I never had this issue and the box was connected exactly the same way using the same PC as NAS source for all local LAN movies.
So what I have done is change the Kodi cache settings back to "0" where only internet streams get buffered. This way, I am able to watch the movies on my LAN but every now and then they will reach spots where the total data being transferred wirelessly is large or if there is a sudden wireless interference and so the movie will stop until buffer is reached again and resume so yes it isn't ideal but at least this way I am able to access my movies.
Has anyone encountered such an issue? It is really frustrating especially considering I have tried this with the Voyo PC with 64GB SSD and 2 GB RAM but also with the V1900 chip with 8 GB Ram and 128 GB ssd.
Tnx for any help.
