Ourspop MK808B Plus no output and power led, broken after finless ROM
    Hey everyone let me start out by saying i am very new to all of these android tv sticks. I bought a Ourspop MK808B Plus on amazon hoping I could use it for netflix, kodi etc. I got it all setup and Netflix had severe audio lag and bluetooth was not working properly. So i decided to flash it with a costom finless ROM hoping it would solve those problems and maybe disable the HDMI check Xfinity TV Go app uses so I could actually use this app.
    I loaded the Finless Rom onto an SD card, and watched as it installed. After it finished and rebooted, I get a black HDMI output, and no power light. Is it broken? Am i still able to reset the nand flash by shorting pins 8 and 9 on the CPU? I need some real help here i am very new to this, thanks!
    I had the same problem, reflash back to stock using the info in this thread, then reflash Finless. DO NOT flash Finless if it's a newer one, though, the wifi won't work.
