MK802IIIS New Firmware NEOTV CR 1.9 for all Version
    Re: MK802IIIS New Firmware NEOTV CR 1.9 for all Version
    Originally posted by andypen View Post
    Thanks Neomode. I'll have a look at those options too. I have virtualbox installed so just need to find a test download.
    Leolas - are you saying I can just rename one of Neomode's 7z files to update.zip and install it that way, or are you refering to installing CWM recovery? I've used CWM for the last few years with my phones and CM and love how easy it is to flash.
    Nop, not so easy, I want to say that you can download from androtab your specific cwm_device.zip and rename it to update.zip to install cwm recovery in the stick. To make a cwm zip flashable Rom you can do it following one thread in this forum, I made a template zip to flash your Rom with cwm recovery. But take care, cwm can't resize partitions size so if the Rom you use have a very large kernel.img or system.img(like 4.2.2 versions for some devices) they will not fit in the partitions you have.
    Good spanish neomode
    My devices:
    Gearbest.com)
      wow, nice spanish bro, okei, i will try now 1.7 NEOCR version, its rare because before i tried 1.8 and finless 1.7 too, and still not work, my MK802IIIS have like 6-8 months i think, but well, i will try now and post to you the response
      Originally posted by neomode View Post
      Hola,
      Por favor, vaya a la versión 1.7 de NEOCR. Creo que es posible que tenga un primer modelo. Es igualmente posible que hay otro módulo de Wi-Fi.
      Si todavía te estás preguntando de inicio de sesión de nuevo :-)
      Saludos
      NeoMode
        neomode you can upload again 1.7? because is corrupt, i cant extract zip, this http://www.freaktab.com/showthread.p...on-1-7-Neomode
        thanks bro
          AW: MK802IIIS New Firmware NEOTV CR 1.9 for all Version
          Please use 7zip or izarc to unpack the file.
          Thx
          Neomode Freaktab.com Developer
            Hi Neo,
            1.9 Rocks. Thanks for getting rid of the pizza slice from the future mouse cursor. That always bugged me about the MK802IIIs. Everything runs great. Thanks for all your hard work!
              Thx you I also don't like the original Mouse Courser. Tho I make a new with more contrast.
                Hola,
                Saludos
                NeoMode
                i just test now, and with 1.7 NEOCR still wifi dont work, i put on switch "ON" and put "Scan for devices" but not more, not find any, any other solution?
                thanks
                  i restored my mk802IIIS BT to rikomagic basic firmware, and dont work wifi yet, i dont know if the wifi antenna is broken or what, i dont gived any blow for break wifi antenna, so, wifi and bluetooth both are disabled, i cant connect both,
                    To options for you Wifi Chip or Wifi Antenna is defekt. Open the housing and look inside.
                        Make me a photo from both sides and the Wifi Chip. I have a feeling something is wrong.
                          i dont know where is the wifi chip, so, i put this photos, if you need other more tell me, and i will do, what do you think?
                            Please make a closer photo from the orange pcb layer near the wifi antenna.
                              Originally posted by szmorce View Post
                              hello
                              I have an usb lan adapter.
                              I see mac address in ethernet settings , but didn't get ip address.
                              I tried to set satic ip, but didnt solved my problem.
                              Sorry for my english.
                              Someone have an idea?
                                you want say this? or yellow chip? sorry for my bad quality photos, faking iphone4
