Cannot connect Ugoos to PC
Make sure to use the OTG cable that came with it as SOME cables will NOT pass data and are constructed for charging devices only.
Make sure you have properly installed drivers
Make sure BOTH ends of the OTG cable are fully inserted into the device and the PC. Also make sure that the USB port on the PC is functioning properly.
In USB settings on the device I think it needs to be set to media device
In Developer settings I think you need USB debugging ONFLHT = Harley
HEMI = 2010 Dodge Challenger SRT
Cause I've been asked.
There are currently 1795 users online. 1 members and 1794 guests.
