Meegopad T02 Recovery image
    Hey Guys,
    I have a morfine m1 and as far as I can tell its the same as meegopad t02 - Over the weekend I had some software failure on the windows side and I had to delete all partitions to get it booting to windows again and I got it working now but the issue is the android os was removed in the process. The 8gb partition is still there and setup should be really easy but I cannot find the damned android 4.4 os image anywhere. Does anyone know where I can find a working dual boot android img file? The way android looks on the m1 is it has a windows icon in the middle to switch the OS and its NOT done through the quick launch menu. Not sure if the T02 is the same software wise but physically they look the same. If anyone has a link they can provide I will be very grateful.
    Thx!
    Figured it out. Found linuxiums image @ https://goo.gl/eyOxMF and it worked perfectly.
      Good to hear.
