Andoer CS918 RK3188T // rk918 v1.20. bricked, need firmware!
    hi there, am new to this forum....i hope you can help.
    brand: Andoer
    chip: rk31 CS918 RK3188T
    board: rk918 v1.20
    features: 2 GB DDR3 // 16 GB NAND
    play store id: gxt_stb_3188
    http://wp10612258.server-he.de/musik...7112238825.jpg
    in the lower right corner is an rtl chip, but i cant figure out the labeling. (same at the other processors, to dark). i tried to make the sticker away from the cpu, but that was no sticker, its silvergrey, on the cpu and it cant removed only scratched.....i hope that this is only a kind of cooling and no transistors are damaged).
    its bricked after trying to root it. with the usb connection you always had to switch usb memory on manual, otherwise you couldnt write on it (for pushing su or something like that). so i missed that, low level format worked, reboot too, writing on partition not. so it was pumped out.
    some roms gave flickering glitches on the scart tv out (hdmi is just blank screen) (as the bootlogoloop, but with various grey glitches randomizing after a time, in recovery its a grey glitch 4:3 tv sized). some just booting up the glitch and shut down (power off) after a while.
    the rk918 v.1.10 dump from the PCB-thread works till bootloop (shows the google ball).
    not working:
    update_Q7_20141209
    rk31_cs918_8723_150121_4.4_8g1g_v7.0
    Geekbuying_TV BOX_RK3188T_Android 4.4_official_AP6210
    EKB311B(CS918)_no logo_ROOT_4.4.2_20150122
    cyxtech_rk31_cs918_8723_141222_4.4_8g1g
    CS918_rk918-v110-20141122_Real
    Dump_CS918_MB_GTX_RK918_V1.10
    there is no firmware by the manufacturer, cause its only a shop with no support.
    recovery and flashing works, as the programm shows it (rk-batch-tool 1.7, android tool 2.3).
    the indicator from the batchtool is green on layer 2-3.
    the android tool shows "found one loader device" in recoverymode, but waiting for mask rom mode failed when trying to erase the flash.
    hopefully that these scratching doesnt damaged something.... help!
    i need the firmware for that....thx in advance!
    solved, works with http://www.mediafire.com/download/da...qbfsw/V580.rar
    I have the same device and the same problem. Did you find some firmware for this device?
      I think i have a dump of the rom from a working one of these units. I'm just not sure how to compile it into a usable flash image. anyone have any thoughts?
        Please share with us this dump. Unfortunately I dont know how to compile but I found this link http://forum.xda-developers.com/show....php?t=2257331
        Its about an rockchip image packer
          Ok I will share. however because i am in canada my upload is ridiculously slow. Can someone advise the proper dump? When I went through mine I found that the block locations were different than the ones noted. I don't have it setup now or i would take a screenshot to show. I will do that tomorrow evening when i get a chance. I see it is using the 3188t chip wich is slower and hampering my retail value due to poor buffering and processing speeds i much prefer the faster 3188 chip.
            Sorry i dont understood what you mean with "proper dump", my english is very poor(is not my native language ). I guess you have to zip the parameter file with .img files and upload for some server like mega.co.nz
            Sorry if Im wrong.
              hi friend, try these:
              MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
              http://www.mediafire.com/download/da...qbfsw/V580.rar good luck
                merci buku, the second one works fine (Rkbatchtool), dont testest the first one.........thx in advance!! )
                  Hi raeumler, you just used the rkbatchtool? What procedure did you use? Because I used only the rkbatchtool version 1.7 firmware and none of these work on my device, which is equal to yours, the second firmware work, but is only restarting the Linux screen. Can you tell me which programs you used, and what procedure to install the firmware you do? Click image for larger version
ID:	524167 Click image for larger version
                    i just used rkbatchtool 1.5en, was green lightend @ layer5-7 choosed the img and clicked "restore". after that the bootscreen was a commandoline with 4 penguins in the left top, which showed that it was not possible to mount the ext_sdcard then normal googleball bootscreen (took about 15 - 20 minutes to start). but then works fine, it has japanese keyboard (language is eng, hdmi works @ 1080) and is not rootable via tpsarky....
                      I noted that my device is a little bit different of yours, raeumler, it has 1gb of ram and 8 gb of rom. the second one didnt work for me
                        Raeumler, unfortunately in my these firmwares not worked, for the four penguins in the left corner of the screen and the device is restarting. If it worked in her, I should work on mine, because our devices are identical. I suspect it is something else that is causing this crash, or is making any wrongdoing, because I could not do the procedure with rkbatchtool 1.5, only the 1.6,1.7, and gave the same result. Does anyone have any suggestions of what is going on?
                          my device crashed after not mounting the flashmemory after lowlevelformat for a new rom (i got a normal linux bootmanager installed which doesnt worked, but formatted after that). the four penguins coming up when boot up first time only, now its real quick in booting. i dont know. i'm sure i used batchtool 1.5EN (with 'en' behind, dont know if there is another). my device has also a "andoer" brand....
                            I have the same box as rauemler.
                            With this firmware, I could get up and running again. http://www.mediafire.com/download/da...qbfsw/V580.rar
                            I have used the BatchTool 1.7
                            Does anyone know if there's already working software at the time?
                            When Stockrom the Ethernet is incredibly slow and I can not play HD Movies smooth via LAN.
                              Hi, I have the same box everything is stock. But I have DTS problems and picture struggle. Is there any good rom and kernel for these box.
