As I am the process of filing a dispute with the vendor through PayPal for sending me a device that was defective on arrival, I am not ready to open it up to troubleshoot the issues yet, but any advice would be appreciated.
Problem with Pipo X8
About a week ago I received my long anticipated Pipo X8. When I started it up for the first time, it ran for 10-15 minutes, and then the screen became all pixelated (see attached picture), followed by it shutting down. I then have to wait at least 15 minutes with the device unplugged before it will start up again. I have this issue in both Android and Windows, so I am almost sure that it is a hardware issue, and more to the point an overheating one. I am wondering if anyone else has encountered similar issues with their X8s, and if so, were you able to fix it?
As I am the process of filing a dispute with the vendor through PayPal for sending me a device that was defective on arrival, I am not ready to open it up to troubleshoot the issues yet, but any advice would be appreciated.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
I have the same issue with my X8. I had to loosen the two screws closest to the front on the X8 on the bottom. This made it more stable. I believe its happening because the thermal padding inside is placing excess pressure on the LCD.
Email [email protected] and inform him about the issue, along with that photo.
Are you also getting the spark coming out of the back of the X8 power jack when plugging in a power pack that is already plugged into the wall? I described my issues in this thread:
Originally posted by Tek View PostI have the same issue with my X8. I had to loosen the two screws closest to the front on the X8 on the bottom. This made it more stable. I believe its happening because the thermal padding inside is placing excess pressure on the LCD.
http://freaktab.com/forum/tv-player-...pipo-x8-issues
I will contact Ben Lai to see if he can assist, and I thank you for all the information. I will keep you posted.
Originally posted by Tek View PostCool. Look forward to the results.
Just so you know, the image you posted and your description are the exact same symptoms my X8 is suffering, so if you believe your case is more serious I would like to know why so that I can test for the same things on my device.
Alas I failed in my efforts to get a full refund from the merchant and PayPal was useless. This said I opened up the device and immediately confirmed my suspicions that the issues are due to overheating and poor heat management. When the tablet/ TV box is lying in its standard position, it is very difficult for heat to dissipate, so it overheats quickly. If you tilt it, that seems to do the trick, but is not ideal. I have ordered a USB cooling pad with fans, which I hope will be a better solution. You would have thought Pipo would have learned with the X7, but no. Good luck with your device.
Sorry to hear about your refund problem.
For me it has nothing to do with heat. It's purely a mechanical problem cos I can control it by pushing on the bottom plate when the screws are loose. Are you 100% sure that by lying on it's side that its not bearing the weight on the internals as it would if it were resting on the feet? Another reason I know its not heat in my circumstances is that it can happen within 1 second of the boot screen appearing, then i mechanically adjust the device and it works again immediately.
In my case, as soon as the tearing of the screen starts, you can no longer do anything, even if you apply pressure and the tearing disappears. The tablet will then switch off, and you must let it cool off, before it starts up again. Also, when I opened it up, it was piping hot, way over the heat tolerance of an electronic device. If you connect a USB keyboard and hit F7 as you startup the X8 you will see that it is set to automatically switch off when the temperature reached 95 F, which it most certainly did in my tests. I can only hope that the fan will do the trick. I will let you know.
Good Afternoon Tek - An update on my Pipo X8: Yesterday I received an email from Tracy @ Pipo with a new version of the firmware to install. Upgrading the firmware seems to have stabilized the device as long as the two bottom screws are loosened (enough for me to slip a folded business card between the bottom of the case and rest of the body); I have been running the device for the last three hours with no issues, so while not pretty, it is better than having a door stop. I thank you for all your help, and if you want me to forward you the email with the firmware (I couldn't attach it to this post as the limit is 20K), give me your email and I will send it to you. Cheers!
Originally posted by probstc View PostGood Afternoon Tek - An update on my Pipo X8: Yesterday I received an email from Tracy @ Pipo with a new version of the firmware to install. Upgrading the firmware seems to have stabilized the device as long as the two bottom screws are loosened (enough for me to slip a folded business card between the bottom of the case and rest of the body); I have been running the device for the last three hours with no issues, so while not pretty, it is better than having a door stop. I thank you for all your help, and if you want me to forward you the email with the firmware (I couldn't attach it to this post as the limit is 20K), give me your email and I will send it to you. Cheers!
Good stuff. Not sure how effective this will be for me but I am willing to give it a go. Like the last poster said, It might be better to upload it to file sharing service so we can all grab a copy. Cheers.
All - After some research on creating cloud shares, here is the link to the file to download:
https://drive.google.com/folderview?...ms&usp=sharing
As for the instructions, this is what Tracy at Pipo wrote me:
"please see the file in the attachment. Please have a try.
Please runby the rights of administrators, clicking the right side of your mouse in Windows."
As for another tidbit, which was of no use to me in troubleshooting, but seems to be the source files for Android and Windows for the Pipo X8, Geekbuying sent me this link:
http://blog.geekbuying.com/index.php/2015/06/17/pipo-x8-dual-boot-system-upgrade-method-186834-20150617/
On a final note, after much pressure, GeekBuying.com offered me a $20 goodwill credit, so thanks to all the invaluable help I received and some tinkering, I have a "mostly working" Pipo X8 and a $20 credit I can use to buy more gadgets.
There are currently 1491 users online. 0 members and 1491 guests.
