Thank you.
Need help with HLSX-CS918 V1.1
I bought a HLSX-CS918 V1.1, when i press the power button with the power cable connected the led turns red for about 5 seconds then the led turns off, when i connect a usb cable the led automatically turned red and 5 seconds later it changes to blue, it goes straight to recovery mode, i tried to restart but it didn't work, so i installed a firmware with Rockchip Batch Tool V1.7 and now the led is always red even with the usb cable connected, now it does not turn on. Do you know any firmware and flash tool that i could use?
Thank you.You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
There are currently 2570 users online. 0 members and 2570 guests.
