Remove windows partition and run only android
Anyone know how to fully remove the windows partition on one of these dual os boxes / sticks? Ive loaded windows via usb and tried to format from the installation area but it always ends up with a partition for windows that cannot be removed @ around 20gb and size and the android one that also cannot be removed which is about 8gb in size. I want to turn this thing into a full android tv basically since windows doesnt run well enough for me to actually use it.Tags: None
Originally posted by trebor View PostShould work
Boot of Windows Usb
do a custom install when it gets there,
Advance button it will show the delete (X) highlight partition delete one at a time.
When done deleting
Then exit the custom install
Then exit the setup that was started
Cheers
Thats what im describing as not working, I can delete all partition but im always left with a blank space of 20gb and 8gb no way to combine the two together
Ok The Version of Android must be for a 8gb set up only
There is a 16gb of the Pipo floating around the Geekbuing Blog.
May have to get creative as ravideep has done in
http://freaktab.com/forum/tv-player-...ipo-x7s-w8-etc
Create your own size EFI Files, (larger partitions) maybe try the 16gb from GB first see if its works then move from there.
Just thinking if you can make smaller cant see why you cant go larger...not 100%
Cheers
Originally posted by trebor View PostOk The Version of Android must be for a 8gb set up only
May have to get creative as Guest has done in
Cheers
Originally posted by alwaysbless View PostAnyone know how to fully remove the windows partition on one of these dual os boxes / sticks? Ive loaded windows via usb and tried to format from the installation area but it always ends up with a partition for windows that cannot be removed @ around 20gb and size and the android one that also cannot be removed which is about 8gb in size. I want to turn this thing into a full android tv basically since windows doesnt run well enough for me to actually use it.
So you don't want Windows and want to give whole space to android?
Replace partition.tbl file with this one and you will get whole of your space in android
Here you go https://mega.nz/#!tNUBFBoC!C4Kbno-EL...dgaFuOIvV-KX0w
Originally posted by ravideep View PostReplace partition.tbl file with this one and you will get whole of your space in android
How / where do i replace this? Also, how would i go about replace the two bioses with one android bios that way I can get rid of the dual os selection screen?
If you follow http://freaktab.com/forum/tv-player-...ipo-x7s-w8-etc
It will get you there, when you run wintoand don't move slider across to show GUI and I think you should be fine.
Cheers
Originally posted by trebor View PostIf you follow http://freaktab.com/forum/tv-player-...ipo-x7s-w8-etc
Cheers
Got ya, technically itll still be dual boot itll just into android by default. On top of that flashing the minix fw doesnt have a switching option so it should be straight android. Thx for the help guys I appreciate it
Ran into a problem with this, when trying to install from the Fat 32 USB Drive im getting a E: Installer device ignored. E: Could not open /sys/devices/virtual/backlight - The Bios for my M1 doesnt have the UEFI built in shell option even after copying the EFI folder and shellx64 file or whatever its called. Im only able to get to UEFI shell by pressing Launch EFI shell from filesystem device and thats when I get those errors - I remember my Minix NEO Z64 doing the same thing when switching back to Android from Windows but it something that ended up working after like an hour of sitting there but in this case I let it sit there for over 4 hours with same results.
Looks like I figured it out, I had go to into the efi folder you guys had linked to and removed the x32 EFI stuff, from there I launched the EFI shell again and got CMD 'Write_OSIP_header', CMD 'Write_OSIP_header' COMPLETE, CMD 'Start_partitioning' CMD 'Start_partitioning' COMPLETE, now its on ERASE Factory... Could not open /sys/devices/virtual/backlight - im gonna let it chill here for a while and see if it does what it needs to.
There are currently 3013 users online. 0 members and 3013 guests.
