Where else can i find the drivers and bios?
Where to find lastest drivers and bios for X7S?
I have just ordered an X7S. When it arrives i intend to do a fresh Windows install. Where do i find lastest drivers and bios? I have looked on Pipo's homepage and i can see there are drivers etc. for the X7, are they the same for X7S? However i cannot read chinese or any other asian language and therefore i don't know what to write and where to click to download the drivers from that homepage.
Where else can i find the drivers and bios?Tags: None
For the bios http://blog.geekbuying.com/index.php...6083-20150502/
& if im not mistaken the drivers for the x7 should be ok on the x7s http://freaktab.com/forum/tv-player-...howing-you-howPlease consider making a Donation to freakTab
Originally posted by blinkone View PostFor the bios http://blog.geekbuying.com/index.php...6083-20150502/
Well, thank you, but its not an upgrade i'm after. I've got a valid Windows 8.1 and want a clean install to get rid of Android. Therefore i don't need the 5,84 GB upgrade, only the bios and the drivers. I found the drivers on the above link, but still cannot find the bios, which should be only a few mb.
Originally posted by fltk View PostWell, thank you, but its not an upgrade i'm after. I've got a valid Windows 8.1 and want a clean install to get rid of Android. Therefore i don't need the 5,84 GB upgrade, only the bios and the drivers. I found the drivers on the above link, but still cannot find the bios, which should be only a few mb.
Originally posted by blinkone View PostTo remove Android then look here http://freaktab.com/forum/tv-player-...-dual-boot-box
But i'm still asking where to find latest bios.
Annoying that one cannot get rid of that dual boot screen.
Wouldn't dear to update the bios with reading about all the problems people got just by changing settings.
There are currently 1780 users online. 1 members and 1779 guests.
