lookin for tv box for video streaming only, no gaming
    currently i have 3d 1080p tv,
    i need a tv box that will be able to handle high quality videos (50-70GB) so gigabit lan is required
    recently the new rk3368 is out, but no gigabit lan
    should i wait abit? for ut4 ?
    my budget is up to 150$
    idea
      for a tv box, 150 dollars is big money, i know want to make full use of your 3d 1080p tv, IN TV BOX market, only RK 3368 CHIP can support 4k FHD , you can go dor tronfy, or beelink, which is enough for video streaming, and i would introduce I68 , ran with RK3368, 2GB RAM with bluetooth and wifi no more than 100 dollarshttp://www.tinydeal.com/i68-px2x7zz-p-154338.html
        Yes, UT4 or Nagrace HPH RK3368 box will be the best
        compared to other RK3368 boxes released it will have
        - External wifi antenna, AC 5Ghz wifi / other RK3368's have internal wifi
        - Gigabit LAN / other RK3368's have 100mbps
        - Bigger heatsink compared to their RK3288 models as they say the RK3368 chip generates more heat. / other RK3368's have small heatsink
        - 3A Power adaptor (Together with the heatsink, will offer overclocking capability) / other RK3368's have 2A
        - USB3 Ports / other RK3368's have USB2
        But UT3S or HPH-NT-V6 RK3288 older chipset boxes have 40000+ Antutu score while RK3368 has 35000+ Antutu score, so the older chipset is still faster but not 64-bit optimized for Lollipop firmware as RK3368 and a little more expensive.
        UT4 and Nagrace HPH RK3368 will be released early August.
          I'm going to assume your 50-70gb files are not really movie files, but full blu ray rips correct?
          If that is indeed the case, then good luck to you, because trying to run blu ray iso is an absolute nightmare on android, even KODI/XBMC won't do it correctly.
          Currently Using:
          2 x Nvidia Shield TV | MiniMX III
          Retired Devices:
          MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
            You are right. It is a full rip.
            Currently i stream the movies with kodi to the internal tv player. The problem the player doesn't support all formats...
            Are you sure that there is no way to run full Blu-ray rip on android.?
            Does ut4 with Ubuntu will handle it? Or just to by mini pc with fresh i3?
            Sent from my GT-I9500 using Tapatalk
              I bumped into several such questions, as gadget geek, I strongly suggest TV Box using Amlogic s812, which is the newest chipset in its rank and give miuch more inportance to picyure and video display. MX4 Telos with Android 5.1, support new API and bluetooth4.1, can be a wise choice. http://www.tinydeal.com/tronfy-px2x8dx-p-154403.html
                I really know nothing about these streaming devices. What do you think about...
                  I really no nothing about these streaming boxes. Does someone klnows Amlogic S802 Quad-Core Cortex-A9 or the like? This devices solds for 63$ US. It comes with android and kodi.
