Change Partition size UT3S?
Hi,Ava
I am really want to know what i have to do for a unified storage.Which values i have to use with PrameterEd.Tool.I have a UT3/2/16GB no Fan,and i want to know how to change the Mountpoints,that a SD Card can be used as internal SD.I know that it is possible for Rockchip i saw it on some Roms from Oma.So you can make from a 16GB Device a Device with unfied storage and 16GB or more as internal SD.
Hope for Info
gefattern
Hello
Im still waiting for Information.I managed to change and flash a Parameterfile with a value of 13778 MB,but after flashing with 2.2.0 it was possible to install Apps but not to use them because there was no internal Storage for the App data.
But under Settings /Storage/internal Storage i had 13,12GB of Space,but no internal SD Card only Mount Settings of course it was not possible to mount internal SDCard,because of no space.
Please help im not the only one how wants this and with changed Mountpoints we could have 16 or 32GB as internal SDCard.
I hope we find a solution.
Originally posted by gefattern View Postunder Settings /Storage/internal Storage i had 13,12GB of Space,but no internal SD Card only Mount Settings of course it was not possible to mount internal SDCard,because of no space.
Becasue root directory and its content is recreated at each boot from readonly image you must change that file. To do so you should use RK32xx_firmware_tool under Windos and extract misc.img partition file and its content.
Then edit fstab.rk30board.bootmode.emmc file. Changing /mnt/internal_SD with /mnt_external_SD. Finaly create new misc.img with that modified file and flash it to your box. It should not disrupt your current firmware and its data.
fstab.rk30board.bootmode.emmc relevant part:
Code:/devices/ff0f0000.rksdmmc/mmc_host/mmc /mnt/internal_sd vfat defaults voldmanaged=internal_sd:14,noemulatedsd /devices/ff0c0000.rksdmmc/mmc_host/mmc /mnt/external_sd vfat defaults voldmanaged=external_sd:auto
Code:/devices/ff0f0000.rksdmmc/mmc_host/mmc /mnt/external_sd vfat defaults voldmanaged=internal_sd:14,noemulatedsd /devices/ff0c0000.rksdmmc/mmc_host/mmc /mnt/internal_sd vfat defaults voldmanaged=external_sd:auto
Creating unified storage like in Wasser's firmwares would be a little harder but also possible with any current firmware. I really don't comprehend why those box manufacturer still divide internal flash storage into data and userdata partitions . That will end all complains about to little space on data or internal_SD partition and any need for many parameter files (2GB,4GB, 5.5GB, 6.25, etc).RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
It will be hard to have unified storage which imply emulated SD card and then swap internal and external SD mount points. It is so because "normally" internal SD is FAT32 partition on internal eMMC and it is mounted by VOLD (Volume Daemon) which reads its configuration from fstab file. When you use unified storage then there is no internal FAT32 partition called "user" but /mnt/internal_sd path is used by SD card emulator daemon therefore external and internal SD mount points cannot be swapped at least not using method mentioned before.
Besides I don't really see any use for emulated external SD card stored on eMMC data partition. Mounting external_sd as internal_sd is quite a good idea.
I understood that you changed "userdata" partition size to maximum possible and removed "user" partition from eMMC (flash storage).
P.S. Can you attach your modified parameter file? Or even paste it here so we can see what exactly you did there .Last edited by Gormar; 11-01-2015, 06:58.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Hi Gomar,
now i am at Home,here the Parameterfile i used,but i only changed userdata to 13778 MB,hope it helps. data8G.parameter_10_10_10.zip ‹
Okey, now I see that you didn't remove "user" partition but reduced it size to few hundred megabinarybytes. It really doesn't mount as NAND Flash storage? Then user partition probably isn't FAT32 formatted.
But that doesn't matter when you want to use external SD as internal. Are you able to extract misc.img and its content to edit fstab.rk30board.bootmode.emmc file?
Changing to unified storage would require modification in at least 3 files from misc.img and one line in build.prop file. And that last part I do not remember.
Side note:
Current partition composition you can see with this command (need root access): "dmesg |grep -i "mmcblk0: mmc0" -A 14".RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 1967 users online. 3 members and 1964 guests.
