Looking for stock rom for m8
    I'm looking for a stock firmware for my m8 none of the stock firmwares I've tried work they all fail signature verification. I have megatron v3 running but only get 720p with it. Tried one stock and it said it was for em8 and said my.box was a mach 8
    Try the armada mach 8 rom v2 with code red launcher do a search in the fourms it's there.
      Ok tries to flash the armada rom sat on splash screen forever does it take awhile on first boot? The lights on the splash screen were still moving so not sure
        I would let it go for at least 1min after that and nothing I just unplugged my and plugged it back in and it booted
          OK will give it a try. Does it have root? On s there a way to root?
            It has root.
              Is that the right one? Or the one from the actual manufactures site?
                This one and choose downloads so you get the v2
                  awesome your the man appreciate the help
                    so went to that site and its downloading but it says 1.2 it takes me to theatreinabox.tv right?
                      Yes sorry it was v1.1 then v1.2
                        No problem I hope it helps!
                          Ok cool will give it a flash and see how it goes. Thanks again
                            Tried the armada rom but didn't have root. Is there a way to root?
